idk if this has happened to any of you guys using Audacity but I was slowing some songs n stuff & when I go to check what amplitude the bass is, it's always around -1 db's & I know it can't be with what songs I was doing. I made sure that my plot spectrum is on spectrum, function on hanning window, size 16384,& axis on log. If anybody could help it would be very much appreciated.
System:
Basically Stock
In process of upgrading
It's been doing that with me as well. I've been using the mic to see where the songs peak at. I disable the mic, then enable it again so that it drops to the bottom. Then I drag it across the screen so I can clearly see where the song peaks at. Hope I helped!
Yea, when I was recording my gmas old records through the mic it started acting weird but luckily I got it all figured out.
what? not sure i understand, use screenshots
if anyone can helps its me :drinks:
I got it all sorted out but thanks man for sure man.
System:
Basically Stock
  • 3 weeks later...
why would u think that's not possible?
I literally just downloaded the song from hotnewhiphop.com, went thru audacity, uploaded on photobucket and look
once you zoom in correctly you can see is actually LOUDER than you thought
Edited by Decaf
well, I looked at White Girl by Jeezy and it says it peaks around 51hz @ -3.1db, and also says Poor Man's Hydraulics is 37 hz @ -1.1db. I remember audacity telling me it was more like -5.7db when it worked properly
This started happening to me as well, can you tell me the fix eltortuga? No way Nightmares Of The Bottom peaks @ 51hz @ -3.4db
I just deleted, then downloaded a new audacity. & that song probably does peak there but it's probably clipped to balls.
System:
Basically Stock
actually no, its just a loud song. there's very simple music in the background and a simple beat, so that allows room for lots of bass
Oh, makes sense, I've only listened to that song a couple times.
System:
Basically Stock
