phlatliner Posted January 5, 2012 Report Posted January 5, 2012 Hi im in need of some good advice I have a 93 Honda civic hatchback I have 8 10 inch jl audio w1 v2 8ohm subs and want to push them with aassive audio n4 in a ported wall tuned to about 31-28 hertz is it possible to do a hair trick with this set up? Please any advice is good advice Quote
IBleedMusick Posted January 5, 2012 Report Posted January 5, 2012 (edited) Hair tricks are caused from moving air, move enough air and you can make someone's hair stand up. This typically works best in SUV's and Hatchbacks so you should be good to go with 8 10's that sounds like enough cone area and with enough port area and the right tuning you will be doing hair tricks but may I ask why you want to hair tricks so bad? Is it just the wow factor of I can do a hair trick? Edited January 5, 2012 by IBleedMusick Quote 2013 Dodge Charger Build Log 1996 Ford Explorer XLT 5.0Build Log 2005 Honda Civic LX Coupe Build Log SMD SUPER SELLER!!!!My Selling Feedback
MIKE-2U Posted January 5, 2012 Report Posted January 5, 2012 ^ hair tricks are from the air. Its not so much the sub/subs but more or less the enclosure design the right notes and the cone area. 8 10's should do a hair trick with the right enclosure but there is really no way to tell unless it is tested. Quote 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
phlatliner Posted January 5, 2012 Author Report Posted January 5, 2012 I guess it is I mean I think if I can do a 4000 watt 8 10inch subs do a nice hair trick ill feel like I've accomplished something just wanted to known if it was possible with my setup Quote
phlatliner Posted January 5, 2012 Author Report Posted January 5, 2012 Imean the subs and are rms at 300 and void warranty after I will be giving them more but at this low wattage is the hair trick possible I guess it is I mean I think if I can do a 4000 watt 8 10inch subs do a nice hair trick ill feel like I've accomplished something just wanted to known if it was possible with my setup Quote
IBleedMusick Posted January 5, 2012 Report Posted January 5, 2012 Again it's more about the design of your enclosure than the power you're putting out. You have the cone area with that many 10's and with the right tuning you can do it. You will need to test it of course but 2400w is not low wattage at all just make sure your electricals can handle doing that much power. Quote 2013 Dodge Charger Build Log 1996 Ford Explorer XLT 5.0Build Log 2005 Honda Civic LX Coupe Build Log SMD SUPER SELLER!!!!My Selling Feedback
phlatliner Posted January 5, 2012 Author Report Posted January 5, 2012 Ok a simple ported wall with a low tune in a hatch with what I have is a 156 db reachable and what do you mean make sure my electrical can handle it? Again it's more about the design of your enclosure than the power you're putting out. You have the cone area with that many 10's and with the right tuning you can do it. You will need to test it of course but 2400w is not low wattage at all just make sure your electricals can handle doing that much power. Quote
mattc3366 Posted January 5, 2012 Report Posted January 5, 2012 Depending on how much power your running your going to need extra batteries and possibly a high output alternator. Quote subwoofers - two eclipse 88120s box - 3.4 cubes tuned to 32 hz amps - aq1200 and pheonix gold zx450 New build : 2 obsidian audio 15s same amp 6.1 cubic foot box tuned to 32 hz in a civic hatch
phlatliner Posted January 5, 2012 Author Report Posted January 5, 2012 Ok so I have the right equipment and car any advice on an enclosure that would help me do this I wanna do a badass hair trick Depending on how much power your running your going to need extra batteries and possibly a high output alternator. Quote
