i just designed this box for two 15 inch woofers. there arent really any box specs for them besides the technical specs which i don't understand so any help would be appreciated tumult 15" d4 specs here
other information, the subs will be seeing 500 watts until i can upgrade my electrical to handle 1900 watts.
and the box will have a double baffle, it will be mounted on the outside and then made flush with 3/4 moldings
anyone?
Posted (edited)
3 cubes a woofer is a bit small.. 90% of 15s out like 3.5 4 cubes a piece..id say do 3.5 a woofer..so they would be more efficient on the lower power u plan on using. if you went 4 cubes it might be a bit much for higher power..
them look like some nice ass subs tho
ur dead on with the port area tho and the tuning should get verry low
Edited by getlocivic
Posted (edited)
damn let me see what i can do to boost the box volume, other wise does everything else seem fine,
Edited by bass_stalker
make sure you do like double baffle sub plate and dont be shy with braces.. always use wood glue.. and liquid nails if u wann aget a reall good seal inside
yeah, or the people that think drilling a hole in a sealed box makes it ported .but i think i may try to swap to 4.5 inches wide on the port or something like that to see if i can get a bit of volume back.
right i'm planning on using 3/4 birch for walls and sides, and hardwood for moldings and bracing. planning on using titebond 2 for holding together the baffles and to seal up where the walls meet
i wouldnt sacrifise port area for a tad more volume..i would however tune it a shave higher..maybe 33 34hz..shit if u want to mount the subs inverted.. see if you can go maybe 1 or 2 more inches taller see what that does
  • Who's Online   0 Members, 0 Anonymous, 470 Guests (See full list)
