how do these box specs look
this should kinda show the area i have to work with, those dimensions are the most i could fit between the wheel wells and between the hatch and seats
would there be any issue with the hatch only being a few inches from the port? i think it may only be one or two inches away
hmmm that back tire is a bitch aint it lol
did you already buy the subs?? bc the website had a VERY hefty pricetag on em.. i said holy shit
actually i'm trading an Xbox for them and a few other things for them, and i wish i had the slim spare tire would be soo much better lol
Edited by bass_stalker
generally u wanna be port distance away from the hatch.. so if u got a 4inch wide port need to be 4inch away from loading wall..BUT depending on application u can move it closer or further away and see how it sounds by ear
ah i may just have to do port up then, see thats where i'm a noob lol i understand the basics but not the things like loading and stuff like that
ever thought about using aeroports??
space is a issue grab a aeroport
i thought of it and that might have to happen, i'm trying to keep the box as cheap as possible but if i gotta get areos to do it right ill wait and save to get em.
what would you figure 2, 4 inch diameter or would i need more, ive never used em.
my last box i did.. was for 2 15" psi reconed tc9s did exactly 7.3 cubes gross volume (gross volume meaning literally a sealed box before any ports in etc etc)... i did 4 4" aeros tuned at 32hz and it was gravy
2 4" ports wouldnt be nearly enough port area
if u wanna improve ur handyman skills u can get some thin walld pvc pipe from lowes or home depot..and heat the ends up and force them over a heavy duty bowl to get the "flared" affect.. ive used both and success with both
Edited by getlocivic
well without the slot port i'm up to 8.56 cubes with 4 4inch areos set to a 10 inch length tuned to 32hz . about 5.87 inches of port area per foot
  • Who's Online   0 Members, 0 Anonymous, 1626 Guests (See full list)
