Need Help kinda of a newbie here
I have a jensen power 760 and it turns on but immediately the protect light turns on can i get help on this issue and also i need a little bit of help on how can i hook up to two 12'' Kiker Comps
Good chance you wired your subs to 2 or 1ohm and your amp can't handle. I don't know a lot about kicker can you give me the model names? if they are DVC or SVC it will make all the difference in the world when wiring them.
But again I think your problem is your initial wiring. However, I've been wrong before ;).
nvm the specs were a little more straight forward than I first thought. You need to do this:
Your amp can handle 4ohm and 2ohm, so I don't really need to know what ohm you have. If I missed anything, I'm sure someone will gladly jump in and help ;).
I would check what Rebel is saying too. Also, you may need to unbridged your amp if it's bridged. My apologies in my skim-reading I thought I read that you had a mono amp. Clearly, I'm wrong. That said, I do need to know what ohm you have:
4ohm
or
8ohm
  • Who's Online   0 Members, 0 Anonymous, 1508 Guests (See full list)
