Yes both of u are right. Series each woofer and run 1 woofer in its own channel @2ohm. The T4k even though it is known as a mono amp, it can be played as a 2 channel amp as well. Like Steve did when he had dual 1 ohm woofers and blew his amps. When he was waiting for repairs on 2 of his amps he ran the 2 subs per amp with the other 2 amps. He series'd each woofer (dual 1ohm) making each sub 2ohm and ran 1 sub per channel. In his case since he has dual 2ohm he would have to go with the T2ks to get his full power.
I thought I did read it
00114-1.jpgTEAM MechMan Alternators
You'll be looking at anywhere between $850-$950
well my friend is sponsored and can probably get 300 off that price FTW! I might do that
Lets Go Ski
bro if you put a T4K on each be VERY careful. You really gotta know what your doing man
agreed...just because you see steve do it doesnt mean just anyone can do it. his box is just right, his signal is just right, his power source is ABOVE PAR (and much more). not saying your not capable of doing it correctly but it takes a lot of fine tuning to give a sub its over MAX power as RMS.
id recommend a T2k or T3k per sub or 1 T4k split between both.
o i know steve has his truck just right...thanks for all the input guys
Lets Go Ski
