Ok guys, after the "1500 watts amplifiers challenge" i took out everything from the sexplorer, is time to move on and try a bandpass for hairtricks using small cone area, but anyways, i was kind of boring and i wanted to try something fun, hitting over 140 dbs with a DAILY box , cheap equipment on small power and very small cone area, all of this things on a big ass cabin :)
1) Step one: Getting a cheap sub, i found a Pioneer Champion TS-W258D4 350 watts DVC 4 ohms for 15$ , it didn´t look that bad actually, price it´s something like 45$ if you get it brand new if i´m not mistaken :peepwall:
Specs:
Features
Maximum input power 1.200 W
Nominal input power 350 W
Impedance 4Ω
Frequency response 20 - 450 Hz
Lowest resonance frequency 37,4 Hz
Sensitivity (1W/1m) 90 dB
Woofer size 25 cm
Woofer material Interlaced Basalt / Aaramid Fibre Reinforced IMPP Composite Cone
Dual 4Ω voice coils: 2 or 8Ω Yes
Voice Coil bobbin type Phenol resin coated glass cloth bobbin
Pole Yoke Type Extended and Vented pole yoke
Magnets Double-stacked, high power
Terminals Push-type
Recommended sealed enclosure 18,4 - 35,9 litres
Surround 3-Layer Fiber Woven Radial Surround
Technical Specs
Nom. Dia.(In) 10
Qts 0,48
Qms 11,52
Qes 0,50
Fs [Hz] 37,4
Vas [l] 17,63
Vas [ft3] 0,620
Vd [l] 0,326
Vd [ft3] 0,01151
Sd [m2] 0,03134
Sd [ft2] 0,337
Revc [Ω] DUAL1.5
Levc [mH] (2000Hz) 2.2 (4Ω)
0.63 (1Ω)
Xmax [mm] 10,4
Xmax [in] 0,41
Zmax [Ω] 96.01 (4Ω)
19.95 (1Ω)
BI [Tm] 14.68( 4Ω)
Rms[Ns/m] 2,920
Mms [g] 143,28
Cms [m/N] 0,00013
Mg.Wt.[g] 2100
VC.Diameter [mm] 48
Eff [%] 0,18
S.P.L. [dB] 90,0
R.M.S.Power [W] 350
Sp. Displacement [l] 1,64
Sp. Displacement [ft3] 0,058
Recom. Enclosure [l] 22,6
Recom. Enclosure [ft3] 0,80
2) Step two: Get yourself a cheap ass amplifier, i used my old trusty Almani PA1100.2 amplifier, it cost about 100$ brand new, no complains about this little baby, i´ve abused it with 4 mids for about 2 years now without a single problem, of course, since the sub it´s DVC 4 ohms i wired it at 2 ohms :)
P.S: I forgot to take pictures of the amplifier, don´t think you need them tho, if you don´t trust me then i guess i could take some pics tomorrow if you need me too :)
Specs:
Almani PA-1100.2
Description
* Soft turn ON/OFF
* Nickel Plated RCA Jacks
* 2 OHM stable operation
* Power and Protection LED indicators
* High efficiency, heavy aluminum heat sink
* Nickel plated power and speaker terminals
* All models are bridgeable and stable at 4 OHM
* Class "AB" Technology MOSFET PWM Power Supply
* Protection circuites against: Overload, Thermal, Reverse Polarity
* RMS Power @ 4ohm: 275W x 2
* RMS Power @ 2ohm: 550W x 2
3) Step three: Get yourself some cheap ass plywood (had some scrapp wood on my storage so i didn´t spent anything on this) , screws, glue and wires, total cost: around 32$
4) Step four: Build your ugly ass box with your cheap materials, box specs: 1.2 cubic feet and 17.5 SQ of port with a 40 hz tuning :)
5) Step five: Get your ass to my "SPL Gains topic" and use some of the tips i tested over there, if you haven´t visited yet, check it out, use as many things as you can.
SPL gains topic
Printing vynil :)
45´s on the pressure corner: DONE!! (no pics)
Roundover on the sub hole : DONE!! (no pics)
Sexy ass flare using 3/4" pvc strips outside and insinde of the port:
Tape around the sub:
And finally, metering your ugly ass box on your SUV:
Score is sealed on the dash @ 47 hz, plays very nice from 40 to 50 hz, below or above those points it sounds like shit, lots of clipping on that score since i was too lazy to set the gains properly because i don´t give a fuck about that sub lol, so i just burped rolling up the volume knob of the HU and that was it, also, i bass raced a 139.4 using a song from my boy Decaf wich is constant @ 47 hz, with a couple of tweaks i´m sure i could bass race a 139.9 but i´m just lazy as hell since it was just for fun, hope you guys like it :drinks:
Edited by fecupe2001
Double post FTL, sorry about this mods, please close :noob:
  • Who's Online   0 Members, 0 Anonymous, 833 Guests (See full list)
