Been a member here for awhile just to look up random tidbits of info, but finally got a decent setup going.
I didn't get a lot of pictures, but just took some randoms along the way.
3 12" Type R
1 mrx-m100 amp (1000 @ 2ohm)
1 farad cap
6.5" type R door speakers
stock headunit using LO converter (Apt parking & college parking...rather not get it stolen)
The box is around 6 cubic feet (40w 13.5h 24L), with 3 individual chambers each getting around 2 cubes...used a ton of calculators and each chamber has a 4.5" wide by 14in long port so each is tuned to 36-37 hz. The ports are facing the cabin. Probably some errors along the way but idk. Might try a new box design sometime soon but not sure what the best bet is...not like their is a lot of options the damn thing took forever to get in.
I put some cheap sound deadner around the trunk for now (not very effective but it did a little) but I have some "spectrum" sitting in the garage for when there is a good time to spray the trunk.
I want to eventually upgrade and get another m100 or possibly run 3 m50's instead (500 a sub). I also plan on getting a better battery and ditching the cap...but for now this setup gets the job done.
Definately open to any suggestions and I have no idea if these img codes will work...
Build In Progress for Slamology 2013
3 m1xl 18s walled in a gti
1 5k
4 batts
audio technix 1/0
8 cheap r/f 6.5s
mb quart 4.60
