My wifes car has a punch 1000 amp that powers an AQ HDC3 wired down to half ohm, but here lately it has started to go into safe mode but i can not figure out why. i have already checked all of the fuses and checked the voltage (which is staying stable). any suggestions on what might be going wrong or is the amp just done with its life its gone threw three different systems, my wifes being the third, each at about a year a piece. the amp will stay on if it is not played loud with the gain about half. if the the remote gain knob is turned up all the way it wont go past 40 out of 60 on the volume on the stereo. itll go about 50 out of 60 at half remote gain knob depending on the song.
Edited by distinktbean
check and double check your voice coils in your subs a bad voice coil can easily make an amp go into safe mode, and also your gain should be all the way up, thats just begging for a blown sub
the amp has a remote gain knob to turn it up and down, but the system is tuned with a scope so i know im not running it at full all out full gain. i do know that much.
I believe rockfords go into protect anything lower than .7
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
the coils are dead on .5 ohm. voltage stays in the 14's. but the amp goes into protect then if u turn it down a little bit it comes back on. i think its the amp. i have looked at it personaly thats all i can come up with
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
its been fine for 3 months or so at .5
pioneer DEH-P8400bh
XS Power D1200
Shuriken BT-100
audioque 120.4
2 audioque 2200d
big 3
479-418-3056
i've been having the same problem with a jl 500/1 amp.. everything checks out fine. but when u turn it a little to loud it will shut off, then cut back on once u turn it down.. if u find the answer please post it.
if you believe that the amp sees .5 at all times while playing music, you must be insane. only reason that amp has been working (and probably the reason why its not working right now) is because of box rise
i really think its the amp dieing. no dead spots in the coil, no harmful voltage drop, that amp wasnt designed for .5 nominal straight up. what sub and coils do you have
pioneer DEH-P8400bh
XS Power D1200
Shuriken BT-100
audioque 120.4
2 audioque 2200d
big 3
479-418-3056
No kranny im not stupid. im just saying it has been fine for 3 or 4 months and nothing has been changed. voltage is good and coils arent burnt. so that leads me to believe it is the amp as the amp was never designed to be ran at .5 nominal impedance.
Edited by t-money
pioneer DEH-P8400bh
XS Power D1200
Shuriken BT-100
audioque 120.4
2 audioque 2200d
big 3
479-418-3056
