MIKE-2U Posted January 18, 2012 Report Posted January 18, 2012 1. At what point do you need a new alternator ( h/o)? what are the signs on needing to upgrade? 2. At what point do you need to upgrade your battery ? signs? 3. At what point do you need to ADD a battery/batteries? 4. How can you tell if you need to add batteries or upgrade to a bigger alternator ? thanks. Quote 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
pa-pa-platypus Posted January 18, 2012 Report Posted January 18, 2012 hate to be obvious..but significant voltage drop lol Quote This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
MIKE-2U Posted January 18, 2012 Author Report Posted January 18, 2012 So how do u know when the power is coming from the battery because the alt is maxed out or off the alt? I never really understood that part? Quote 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
MIKE-2U Posted January 18, 2012 Author Report Posted January 18, 2012 I meant wheb the alt is having all its amps used how can i know this byba volt meter or what not Quote 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
MIKE-2U Posted January 18, 2012 Author Report Posted January 18, 2012 Ok. Well for my system aq 2200d @1ohm and ill be getting a nice 4 channel what would i need besides new stock battery. I did big 3 i have stock 125amp alt. Do i need 2 batteries? Quote 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
Guest Posted January 18, 2012 Report Posted January 18, 2012 alt is being used 100% when voltage drops to 12's. Then the batteries start to get drained Quote
MIKE-2U Posted January 18, 2012 Author Report Posted January 18, 2012 ok thankyou Quote 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
