TThe groundimg of your batts through a piece of 0 gauge wire, negative to negative, will only be good if you have upgraded the grounds underneath the hood. By doing the big 3
You can ground a batt in the same spot as another batt's ground.
But you want to do the big 3 and up the groundage in your vehicle before adding those batts.
ok cool if i need more help can i PM you just in case i get confuse?
aka KHRISS
Yea its fine.
But continue to post in here so others can comment and give you more suggestions!
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
Yea its fine.
hey larry can i do a 0 gauge from ALT to front battery then continue to the second and third battery ? then just ground the two back batteries in the back on some good ground spot and i do have the big 3 already ??????
aka KHRISS
will this kit be good enough to transfer enough juice to the front and two back batteries ?????
20ft(6.1m) Blue 1/0AWG power wire
3ft(0.9m) Black 1/0AWG ground wire
5ft(1.5m) Blue 4AWG power wire
5ft(1.5m) Blue 4AWG ground wire
20ft(6.1m) Blue 18AWG remote lead wire
1 Kicker 09FHA Fuse holder with 300 amp ANL fuse
2 Kicker 09DB1448 Distribution blocks
aka KHRISS
  • Who's Online   0 Members, 0 Anonymous, 677 Guests (See full list)
