Go-N-Def Posted January 22, 2012 Report Share Posted January 22, 2012 When you buy a good h/u and it comes with good eq built-in, How do you set your amps when they also have crossovers? Do you match them? So if you have the h/u working your highs at 125hz do you put your amp at the same. Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL Link to comment Share on other sites More sharing options...
the1uwannab Posted February 15, 2012 Report Share Posted February 15, 2012 If you want to use the stereos eq just put the amps into full pass which turns the crossovers off if your using the amps crossovers and the stereos they interfere with each other so use one or the other hope this helps Link to comment Share on other sites More sharing options...
