TwinkeyMerchant Posted January 23, 2012 Report Posted January 23, 2012 So i know the VVX's say 600w rms.. but i've also heard from various people that they are under rated.. so post what you have running to theses 15's and what you think they can handle for a daily sq.. maybe pushing them a little hard then normal lol im like 40/60 on sq/spl anyways i was thinking a AQ 2200 on 2 of these at 1 ohm? anyone think that they couldnt handle that or any suggestions?
BigPimpin91 Posted January 23, 2012 Report Posted January 23, 2012 The 2200 on two would be fine. just be ABSOLUTELY SURE not to play them at max volume for too long. Play it safe, even set the gain lower if need be. BigPimpin91's Banging Music
TwinkeyMerchant Posted January 23, 2012 Author Report Posted January 23, 2012 The 2200 on two would be fine. just be ABSOLUTELY SURE not to play them at max volume for too long. Play it safe, even set the gain lower if need be. thanks man, i figured they would hold up and yeah i usually set my gains a lil over half just to always make sure.. i'll probably end up getting this set up
95legwagon Posted January 26, 2012 Report Posted January 26, 2012 The 2200 on two would be fine. just be ABSOLUTELY SURE not to play them at max volume for too long. Play it safe, even set the gain lower if need be. thanks man, i figured they would hold up and yeah i usually set my gains a lil over half just to always make sure.. i'll probably end up getting this set up /\ this..... set the gains with a oscope or dd-1 if you can.... when i hear someone say that they set there gain "only 3/4 the way up!" or a lil over half makes me cringe knowing its entirely possible for a brand new sub to see dirty power and never live its life to its fullest potential lol i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks. / LOL My Low Budget Build: Green 1995 Subaru Legacy wagon 147k- $1K headunit- pioneer premier deh-p650-$25 4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50 4 vvme L11 10"s <- $30 shipped a piece 6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more 2 aspm 1300 strapped Selenium 6"s in the front doors on headunit power- for now -$20 quantum tweets in door-for now -$10 boston acoustic 5 1/4 in rear doors- for now-Free big 3 1/0 and 4awg throughout. roof sound deadened (not peel n seal ftw)-free on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test about $430 for everything<----Not bad at all still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
