wire them down to 2 ohm? it would end up being 1 door per channel roughly, but you would want to set your components up for right and left. That would eliminate the need for your second amp. Does your mono amp have an rca out? if so just use that
it said these speakers arent recommended for 2 ohm but idk. and 1 channel per door wont be enough power. it's 2 6.5's and 2 tweeters per set
get a audiocontrol MATRIX its a line driver since its a one RCA output H/U im guessing 2 volt if lucky the MATRIX makes your 1 RCA output to a 8 volt output times 3 for 3 amps giving you a better signal to your amps better signal = better sound quality
aka KHRISS
Thanks for the help. and i have 2 RCA outputs not 1
