dfarres Posted January 24, 2012 Report Posted January 24, 2012 (edited) Can someone please help with the dimensions for a t-line box for the two options below??? Not sure which would work out better? Right now I have the 2 12's in a sealed box in the truck of a 93 Civic. It has a RF 150a2 running them but i also have a Sony 200 rms in the garage. Obviously I don't have a lot power but it sounds pretty good right now but I wanted to try something new. I've made lots of boxes in the past but calcs on this box are driving me nuts. I put the info on the speakers i have ... if i left anything out just let me know. thanks for any help in advance!!!! 10" Sony Sub (xs-L1030) Impedance 4 ohms Ideal Sealed Box Volume (cu.ft.) 0.7 Sensitivity 88 dB RMS Power Range (Watts) 32-120 Mount Depth (in) 5 Vas (cu. ft.) 1.97 Fs (Hz) 27.2 Qts 0.67 Qes 1.03 Qms 3.75 Xmax (in.) .16 Sd 53.7 sq.in. (2) 12" JL Audio Subs [12w0-8] Impedance 8 ohms (wired for 4) Ideal Sealed Box Volume (cubic feet) 1.5 Ideal Ported Box Volume (cubic feet) 2.5 Port diameter (inches) 4 Port length (inches) 13.6 Sensitivity 88.5 dB RMS Power Range (Watts) 125 Mount Depth (inches) 6 Cutout Diameter or Length (inches) 11 Vas (cu.ft.) 5.65 Fs (Hz) 23.2 Qts 0.425 Qes 0.477 Qms 8.974 Xmax (in.) .34 Sd 82.3 sq.in. Displacement .07 cu.ft. Edited January 25, 2012 by dfarres Quote
STEvil Posted January 24, 2012 Report Posted January 24, 2012 not even a question, stick with the JL's. Not likely to fit in a t-line in your civic though, unless you get creative with some cardboard construction tubes (they're meant for cement forming) then some fiberglass.. Quote MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
FroznBeavrBALLs Posted January 24, 2012 Report Posted January 24, 2012 I would just do one of the JLs. Tlines are normally pretty big for even just 1 sub. 2 probably would not fin in your car. Quote 2 DC 12" lvl 4s 1 DC 1.2k XS Power S3400 big 3 Alll KNU wire Pioneer HU cheapo Legacy coaxes (just for now) http://www.stevemead...n-sentra-build/
dfarres Posted January 25, 2012 Author Report Posted January 25, 2012 Can't do 1 JL cause they are 8ohm. Anyone have any t-line box info for the 10"? I'll make it just to see if it sounds good. The area of the space is 35"x14"x24" that i have to work with. Quote
cc_audio Posted January 25, 2012 Report Posted January 25, 2012 I used to have one of those Sony's, I put it through hell. Tough little sub. do the JLs, and skip the T-line if you can't make it fit. There are other box designs that are more practical. Quote It's all gone! The Celica Build Feedback If I buy something from you, DO NOT USE FEDEX!
dfarres Posted January 26, 2012 Author Report Posted January 26, 2012 (edited) Will this box work for the 10" Sub? The port is 54 sq.in. The box height is 14" I think the tuning will be about 33Hz Edited January 26, 2012 by dfarres Quote
Dax Posted January 26, 2012 Report Posted January 26, 2012 how tall would that box be? Quote The Midget Looks Into Your Soul 2008 Dodge am 3500HD with the 6.7 Cummins Race Me tuner, dpf deleted kenwood double din cheap walmart speakers for now(infinity reference comps comps coming soon) 2 kicker L5's in a ported box of unknown tuning lol(soon to be changed) Power acoustic 1500.1 on the subs (for now)
