Help with T-Line box (2 options)
Can someone please help with the dimensions for a t-line box for the two options below??? Not sure which would work out better?
Right now I have the 2 12's in a sealed box in the truck of a 93 Civic. It has a RF 150a2 running them but i also have a Sony 200 rms in the garage.
Obviously I don't have a lot power but it sounds pretty good right now but I wanted to try something new.
I've made lots of boxes in the past but calcs on this box are driving me nuts.
I put the info on the speakers i have ... if i left anything out just let me know.
thanks for any help in advance!!!!
10" Sony Sub (xs-L1030)
Impedance 4 ohms
Ideal Sealed Box Volume (cu.ft.) 0.7
Sensitivity 88 dB
RMS Power Range (Watts) 32-120
Mount Depth (in) 5
Vas (cu. ft.) 1.97
Fs (Hz) 27.2
Qts 0.67
Qes 1.03
Qms 3.75
Xmax (in.) .16
Sd 53.7 sq.in.
(2) 12" JL Audio Subs [12w0-8]
Impedance 8 ohms (wired for 4)
Ideal Sealed Box Volume (cubic feet) 1.5
Ideal Ported Box Volume (cubic feet) 2.5
Port diameter (inches) 4
Port length (inches) 13.6
Sensitivity 88.5 dB
RMS Power Range (Watts) 125
Mount Depth (inches) 6
Cutout Diameter or Length (inches) 11
Vas (cu.ft.) 5.65
Fs (Hz) 23.2
Qts 0.425
Qes 0.477
Qms 8.974
Xmax (in.) .34
Sd 82.3 sq.in.
Displacement .07 cu.ft.
Edited by dfarres
not even a question, stick with the JL's.
Not likely to fit in a t-line in your civic though, unless you get creative with some cardboard construction tubes (they're meant for cement forming) then some fiberglass..
Hammerdown... 1%
I would just do one of the JLs. Tlines are normally pretty big for even just 1 sub. 2 probably would not fin in your car.
2 DC 12" lvl 4s
1 DC 1.2k
XS Power S3400
big 3
Alll KNU wire
Pioneer HU
cheapo Legacy coaxes (just for now)
how tall would that box be?
The Midget Looks Into Your Soul
2008 Dodge am 3500HD with the 6.7 Cummins
Race Me tuner, dpf deleted
kenwood double din
cheap walmart speakers for now(infinity reference comps comps coming soon)
2 kicker L5's in a ported box of unknown tuning lol(soon to be changed)
Power acoustic 1500.1 on the subs (for now)
  • Who's Online   1 Member, 0 Anonymous, 508 Guests (See full list)
