What serpentine belt?
Just ordered a Singer alt and I've heard sometimes that you have to change the belt due to it not fitting right on the new alt/pulley setup. I found the stock belt for my car, 04 Monte Carlo 3.4L, is 70.5" long. Singer said if need be I should get one 1/2" shorter and suggested Gatorback. Problem is the belt I would otherwise use is #4060705 and has 6 ribs....no 70" 6 rib belts, but they do have a 60" 7 rib belt...would that be a problem? If so, what other belt would be suggested?
Alpine CDA-117...Memphis 16-X03
CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6
Soundstream Rubicon 1.2500d...Digital Designs 3512f
Guest DC Power Kyle
I'd use Gates over gatorback all day, any day.
Really? Why is that? What do you like about the Gates belts as compared to the Gatorback?
The 7 rib belt would get torn up because it can't fit over your 6 rib pulleys so the sides will curl up.
Alright, thanks
Well, looks like im stuck with Gates regardless cause Gatorback doesnt have a belt for my application just 1/2" shorter. Thanks for the suggestion
  • Who's Online   0 Members, 0 Anonymous, 2025 Guests (See full list)
