Hello
I have this subwoofer and i need help for a new box ...
I usually listen Rap ( slower tracks )...
My car its VW Golf 3 ...
this is my old box ...( 93x35x48cm)
Sorry for my bad english...
Some help ?
Ford Mondeo Mk3
HU: Alpine CDE-9880R
Subs: 2x Digital Designs 515
specs are here
Subwoofer with a diameter of 460 mm and 5400 watts of max power.
Specifications
System Subwoofer
Diameter (mm) 460
Peak power handling capacity 5400 watts
Nominal power handling capacity 1800 watts
Sensitivity 94 dB (2.83V/1m)
Frequency response Hz 20 - 200 Hz
Impedance 2 x 2 Ohm
Cone material Carbon/fibreglass
Installation depth 245.0 mm
Installation Ø 420.0 mm
Hole circle 452.0 mm
Included Design cover
Thiele/Small parameters
Fres 37 Hz
Qts 0.6
Qes 0.71
Qms 3.8
Vas 36.7 l
Xmax + / - 15.0
Enclosure recommendation
Bass reflex 60 litres
Tunnel Ø 2x 10 cm
Tunnel length 2x 80 cm
you want someone to design a box for you?
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
​​*Upcoming* SSA Xcon 18 4th order
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
KnuKoncepts 1/0 big 3
Shuriken BT-100 under the hood
Shuriken BT-120 in the back
i'm new in that...
So, i want make 150L+
But i have problem with aero port ( I use 1 or 2 aero fi.16? )
Ford Mondeo Mk3
