I bought a pair of 6x9 alpine type S's. I will be running the off a 4 channel amp but only use channel 3 & 4 (1 & 2 for front) . What do i look for on the specs of the speaker to know what to set the lp filter to and the hp filter too. Also do i set it to full lp or hp ? thanks
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
if you place them in the front what ever channel that says front if in the back what ever channel that says REAR
Edited by KHRISS
CURRENT SYSTEM
(VEHICLE) 2005 JEEP GRAND CHEROKEE
(HEAD UNIT) KENWOOD KDC BT848U
(DASHBOARD) INFINITY KAPPA 32.9CF
(FRONT DOOR) JBL P693
(REAR DOOR) KENWOOD EXCELON KFC-X1730
(TWEETER) KICKER KS25 X 2
(SUB WOOFER) COMING SOON
(4 CHANNEL AMP) ROCKFORD FOSGATE T1000-4ADCP
(1 CHANNEL AMP) ROCKFORD FOSGATE T2500BDCP X 2
(PROCESSORS) AUDIOCONTROL DQXS & EPICENTER & MATRIX PLUS & DDC
(BATTERY) 1 OPTIMA YELLOW TOP
(SIGNAL WIRES) KICKER XI
(POWER CABLES) KICKER PKD1
(SPEAKER WIRE) KICKER 12 GAUGE
(INTERIOR) DYNAMAT
COMING SOON
2 FI SP4 18 COMING SOON
2 XS POWER XP3000 COMING SOON
DC POWER 270XP ALT COMING SOON
6" x 9" Type-S Series 3-Way Car Speakers Power Handling: Peak: 520 watts per pair / 260 watts each RMS: 170 watts per pair / 85 watts each (CEA-2031 Certified) Frequency Response 65 - 23,000 Hz Impedance (Per Voice Coil)4 ohms
Edited by KHRISS
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
\so the lp filter 65 and hp filter is 23k hz ?
im not too sure but you only use the high pass you amp should say HP AP LP you put it in HP
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
why do i set it to hp ?
because LP is for SUBS low frequencies and HP is for high frequencies for tweeters and mid range speakers
A high-pass filter(HPF) is a device that passes high frequencies and attenuates (i.e., reduces the amplitude of) frequencies lower than its cutoff frequency.
High pass means "from here up" Low means "from here down" The slope is how fast it stops the choosen frequency. It's not like building a wall.
Edited by KHRISS
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
Set hp to about 70
RAY please tell me that i learned something all this time is my info correct ????
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
