elflako17 Posted February 1, 2012 Report Share Posted February 1, 2012 (edited) Hey guys my dad just got me this amp in which is a decent amp for 100 dollars I was impress now here are the specs Directed D1200 amp Class-D Monoblock Amplifier Super-efficient Class D PWM design runs much cooler than conventional amps RMS Power Output: 300 watts x 1 chan. @ 4 ohms 400 watts x 1 chan. @ 2 ohms 600 watts x 1 chan. @ 1 ohm High-speed MOSFET switching power supply High-current complimentary Class D MOSFET outputs stable into one ohm loads Thermal, DC offset, reverse polarity, and short circuit protection with status LED Continuously variable 12dB/Oct low-pass crossover Switchable 24dB/Oct. subsonic filter Switchable 8dB bass EQ Switchable 180° phase inversion Remote subwoofer level control Master/Slave Function Variable input sensitivity: 150mV - 7.5V Chrome-plated wire terminals and RCA connectors ensure maximum signal transfer Rugged 2-piece heatsink and cover RCA Outputs: 1 pair LED/FAN Connector: provides power for optional LED light or cooling fan 1-year SonicElectronix.com warranty Now he got me 2 kenwood 12" subwoofer with single 4-ohm voice coil Stainless steel-coated polypropylene cone with rubber surround 1200 Watts Peak power handling 400 watts RMS power handling Frequency response: 25-800 Hz Sensitivity: 90 dB Mounting depth: 6-11/16" Sealed box volume: 1.25 cu. ft. Ported box volume: 1.5 cu. ft. Now as you can see the amp is to much for the speakers would the amp be good for SKAR Audio VVX-12" Sub Woofer 4-ohm? Edited February 1, 2012 by elflako17 Quote 2010 Mazda 3 *Rebuild Time* Subs - (2) AA Mayhems 12's Sub amp - (1) Populus Audio TPA 6500 Headunit - Pioneer App Radio 2 Batteries - XS Power (1) D3100 up front | 6 XP950 rear Wire - Sky High 1/0 Gauge wires and RCA's and steve's VM1 Alternator - Singer 260 Externally Regulated Front Stage: (2) PRV Audio 10W650A (4) PRV Audio 8MR500-PhP-4 (4) DS Bullet Tweets | (2) 6.5 Components (Rear doors) Mids & high Amp : (2) Populus Audio 100.4 Processor: Rockford 3sixty.3 The Build Log : http://www.stevemeadedesigns.com/board/topic/175922-2010-mazda-3-2-aa-mayhems-12-pg14-new-video/page-11 Link to comment Share on other sites More sharing options...
elflako17 Posted February 1, 2012 Author Report Share Posted February 1, 2012 and please help me with the hole ohm situation right now the speakers are connected the 2 subwoffers are connected in the 4 inputs and am not really getting any base because am not getting all the power Quote 2010 Mazda 3 *Rebuild Time* Subs - (2) AA Mayhems 12's Sub amp - (1) Populus Audio TPA 6500 Headunit - Pioneer App Radio 2 Batteries - XS Power (1) D3100 up front | 6 XP950 rear Wire - Sky High 1/0 Gauge wires and RCA's and steve's VM1 Alternator - Singer 260 Externally Regulated Front Stage: (2) PRV Audio 10W650A (4) PRV Audio 8MR500-PhP-4 (4) DS Bullet Tweets | (2) 6.5 Components (Rear doors) Mids & high Amp : (2) Populus Audio 100.4 Processor: Rockford 3sixty.3 The Build Log : http://www.stevemeadedesigns.com/board/topic/175922-2010-mazda-3-2-aa-mayhems-12-pg14-new-video/page-11 Link to comment Share on other sites More sharing options...
mattc3366 Posted February 1, 2012 Report Share Posted February 1, 2012 Make sure your wired to 2 ohms but even at 2 ohms your only getting half the power. Quote subwoofers - two eclipse 88120s box - 3.4 cubes tuned to 32 hz amps - aq1200 and pheonix gold zx450 New build : 2 obsidian audio 15s same amp 6.1 cubic foot box tuned to 32 hz in a civic hatch Link to comment Share on other sites More sharing options...
