Twostrokeking's 1995 Chevy Sundown Build! UBL!!! *** UP TO DATE 9/9/12 ***
Well guys I am ready to enter It for SOTM! So this will be my UBL! I want to make this nice and real clean so its easy for people to scroll through. Maybe even Meade himself will see it :D Anyways, I am 15 years old and her is my truck! My parents made me save part of my money ever since I was little and I am damn glad they did... as much as I hated it! Here goes! Chevy for life!
Heres what is going in, and or is in!
Kenwood Excelon kdc-x395 head unit. (KICK ASS HEAD UNIT)
Kenwood Kfc-p703 Components. (Awesome Speakers, Crisp Sound)
2 Sundown Audio SA-8's in a custom ported box!
Rockford Fosgate P1000-1bd 1000 watt amp.
Truck will EVENTUALLY get sound deadened.
Here is my truck. My baby, My life, My everything!
5" lift on 35" BFG Mud Terrains, 15" Eagle Alloy Rims. K&N Cold Air Intake, Tinted as dark as I can go Legally.
Detailed Engine Bay!
Rustoleum under carriage!
Before
After
Led light strips from Autozone!
Made them light up the floor with a flip of a toggle switch!
Installed an EFX Inline fuse, It runs to the distribution block.
Here is the 0 gauge to a distribution block and then 4 gauge to the amps!
These were the POS Infinity door speakers my Dad and I through in when I got the truck.
These are what we put in! With a piece of deadner for each door.
Dad cut out some wood brackets to hold the speakers. He did damn good! (when this was done I didn't know shit about audio, But I wanted to learn!
Here is the Alpine MRV 2300, Its a 500 watt 2 channel. It runs my crossovers, and an cheap POS ultimate audio 500 watt for the sub!
Here is the system that came in the truck, This was taken before I hung the amp on the back wall and added the ultimate.
Here is my Dad and I's truck after we had just detailed them In the drive way!
Him and Me
Console I built while I was bored! Its fiberglass and Bondo.
Filled the side cubbies with Poly fill to help with the rattles!
THE BOX BUILD STARTS NOW!!!
Took Seat out of the truck and got everything all cleaned up ready to fiberglass.
My Truck Build
Spending money on things I don't need, to impress others I don't know.
At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
About to rolls of masking tape on the floor! It runs vertical one way and horizontal the other!
Fuel for the beast! (Me)
Spent 50 bucks on this!
Laid glass up all over the floor! Kinda sticky and hard to take pictures of so this is the only one!
I had a box all framed up to use and I decided it wasn't going to work so I started over! Had the glass layed up and attached to the box but cut it out because I went a different rout!
The box I started!
Cut out the glass!
Sanding and I ran a 3 Inch piece of wood through 2 of my fingers!! Where the bandaid is those 2 fingers were stuck together.
Glass fits in perfect!!
I can't find the actual cut pictures! Efff! Anyways here is the box dry fitted.
Glued and screwed it all together! Had to notch out the back piece of the box so that it fit perfect around the tranny humps.
Glassed the bottom of the bottom of the box into the frame!
In bass we trust!! Love SMD!!
Here is the top!
Wavy and looked like shit. I wasn't happy at all.
Had to be fixed! Cut out a perfect new top! cleaned off my bench! First and Last time anyone will ever see that! (;
My Truck Build
Glassed in a brace!
Screwed top on and into the brace!! (:
Sturdy as hell!
Test fitted the box in the truck and it fits like a glove! Btw the wing things off the sides are to make the box look like it goes all the way a cross!
By this time it was Christmas and I got a few things!!
Installed HID's!
4500K on the right, Stock on the left!!
My Truck Build
HID's!
Stock!
Stinger voltage meter!
Some wire to make it long enough!
Mounting spot right next to the toggle switch for the LED's!
This is me and my moms saying. She has said this to me for as long as I can remember. Like when I ask her if I can do something or whatever. Got it for Christmas!
Rented this from the library! Great book! Learned a ton! MUST HAVE!!
Then these bad boys came!
Twins!
And the best part! A sticker!
Represent!!
Marked holes for cutout!
My Truck Build
Terminal bolts!
Loops for the 12 gauge!!
$200 heat gun my Dad borrowed from work!
Subs in the box! Perfect fit!
Sub hits bolts so I have to trim them off!
The trusty jig saw!
Heres a shot of the holes I forgot to take! Pretty damn good for a jig saw IMO!
My Truck Build
150' of weather stripping!!
Went around the sub holes to prevent leaks!
Weather stripped around the box so I can test it and see what it sounds like before I seal it up!
This came in the mail!
15' of Knukoncepts 12 gauge speaker wire! LOVE LOVE LOVE THIS WIRE!!
Bought some heat shrink! Blue for positive, and black for negative!
Soldered all connections on!
Got a metal bowl to flare the port with! Bought some 4" pvc pipe!
Flared the port!
To make the terminal holes air tight I used this outlet insulator that came with my weather stripping. Also marked positives and negatives!
Cut hole for port! and weather stripped it!
Got the port in! Used some plumbers tape to hold it in place!
Painted the end of port!
Subs are in! When these were wired I had them for the 2 channel ultimate at 4 ohms. So the wiring is a bit different in the pics then it is now!
My Truck Build
In the truck!
Then my good friend Jason sent me his DD-1 to tune my amps!!
Before the DD-1 came I realized one of the channels on the ultimate was shot so Grandma loaned me the money for the BD-1000!
What that means is I have to re wire all of the subs for 1 ohm! Heres the pictures of that!
Got some carpet from Autozone to carpet the box with!
Made it so I could get into the box if i need to. Id just have to rip the silicone off. That was a dumb idea. and it wasn't necessary.
I let the glue dry over night and then trimmed off the folded over carpet so it sits against the wood nice and tight!
Used this to carpet it! Love the stuff! Its cheap and works good!
Added in two more braces. The subs move air!
Got the box in!
Look what FINALLY came!!
Fosgate Bd1000!
1300 at 1 ohm (:
Got this spare piece of wood for the amp rack!
My Truck Build
Some paint!
More Auto zone carpet!
Painted a spot!
Represent the forum!
Tape marks where the amps will go!
Amp rack in! gotta take the tape off the cross overs! I forgot!
Cleaned up the wires!
Seat in! FINALLY!
Passenger side!
If you didn't notice I had to cut the fin off, I was worried I was gonna plug off the port!
My Truck Build
this is coming along nicely man... Looks great... I always wanted a lifted truck.. ur attention to detail is great..
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
And just for fun! Went and shot guns with my dad yesterday and I got a little muddy (; Not all about Mall Crawlin' (;
Here is some videos of the subs!!
http://www.youtube.com/watch?v=GgsOARxkIRc&list=UUQT8Bf8kfmyeQZ9aLZ3ZYkA&index=2&feature=plcp
VOTE FOR ME!!! FEBRUARY SYSTEM OF THE MONTH!
Huge thanks to all of SMD! I love you guys like brothers and I appreciate everything all of you have done for me! I couldn't ask for more and if any of you need anything I will do my best to help you!
I want to dedicate my build to my good friend Jason also known as Nine8SST, and his beautiful daughter jazzy, you two are the most positive and inspirational people I have ever had the pleasure of talking to. I will make you proud Jason, I owe you one man. Love you guys and thanks for everything!
My Truck Build
  • Who's Online   0 Members, 0 Anonymous, 825 Guests (See full list)
