seriousgary Posted February 5, 2012 Report Posted February 5, 2012 will 2 audiopipe 3k's slam 2 RD Heavyweight v.2 15's dual 2's?
Rogers Posted February 5, 2012 Report Posted February 5, 2012 Yes http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
seriousgary Posted February 5, 2012 Author Report Posted February 5, 2012 what do they do rated true rms?
seriousgary Posted February 5, 2012 Author Report Posted February 5, 2012 and also if I'm running 2 dual 2's and 2 audio pipe 3ks what will each amp be at ohm wise
BigPimpin91 Posted February 6, 2012 Report Posted February 6, 2012 what do they do rated true rms? The do a tad under rated. Clamped mine about 1500w RMS @ 7.2Ω with car off. and also if I'm running 2 dual 2's and 2 audio pipe 3ks what will each amp be at ohm wise If you're running one sub per amp, one ohm nominal or 4 ohm nominal. A.K.A. Get Dual 1's or Dual 4's to run at the 2Ω factory rating. BigPimpin91's Banging Music
2loud4uboyz Posted February 14, 2012 Report Posted February 14, 2012 They love juice my friend to make them happy. Also pull the cover off the amps and blow them out good for lose soildering on board. Trust me on this. You my get a clean one you might get one with lose soildering. I had to fix mine twice from it have lose soildering. Dose good for me for the money. Wish I had a sundown 3500 d or Aq3500d. But don't have that kind of money to spend. Did when I lived home, them days are long gone.
