If you read the jl 1000/1 manual it specifically says the amp will produce less power at lower impedance levels than what is recommened. I second the 2.66 ohm load. its a no brainer anyways given the 1000/1 rips system.
Its on page 10....reduces power in safe mode with loads under 1.5 ohms
http://mediacdn.shopatron.com/media/mfg/9013/media_document/live_1/1000_1_MAN.pdf?1317780748
Wired at .68 i still clamp 940+ from 30-45hz
UPDATE: good news, the problem was in the wiring, i guess too much stress on the amp with the .67 ohm load, so i wired it in series/parallel like the diagram above to 2.66 ohms and all is good now. Given that each sub is only seeing a little more than 150 watts it sounds pretty good. he needs another amp for sure and he should be in business. thanks for all the help guys, much appreciated! :drinks:
2003 Mach 1 Build
HU: Alpine CDA-9857
Sub: Fi Bl 4"VC fully loaded
Sub Amp: RF 1500-1bdcp
Highs Amp: Kicker KX650.4
Highs: Polk Audio db 6.5 comps
Epicenter
Out of the 3 cars i have here, it only works in my truck.
Voltage protects in the other ones.
Really needs a good batt bank to wire low.
  • Who's Online   0 Members, 0 Anonymous, 825 Guests (See full list)
