jg23's UBL, 08 tahoe FI SP4 18s, aq 3500s
well this should hopefully clear if i measured right. also bought a triple alt bracket yesterday
also messed up a little by cutting a bit deep but i was able to fix it lol
thanks to ray for helping me out with this
tried to get them all flush mounted. it came out ok
for now im going to leave it as is, im going to get it playing and we will be metering it to see if its worth finishing
Box is in and I'm on my way to rays
2008 TahoeHU-PioneerMids/Highs amp- sundown 200.4Mids/Highs- hertz xls, hertz ml 700, audison voce tweetsAmp-2 AQ 3500sSubs-FI SP418sAlt-singer 350Big 3 1/0
Build Log
UBL My YouTube channel
heres the results from today
Well today we set the amps with the dd-1 and cc-1.
First thing we tried was an amp per coil unclipped.
Did a 50.7
Then we strapped at .7 unclipped also I believe
Build Log
so today i got the the mille 3s and ray helped me put everything in and it sounds awesome. i surprised on how much mid bass im getting right now
i got the 200.4 in and everything is back to normal after a small setback lol
replaced my old tweets today
im going to try and make a new and better distance vid tomorrow but i just need to find a spot to do it
Build Log
  • 1 month later...
New batteries also. Might be selling the other batts soon
And to go with the batts I got some Projectdb bus bars
Build Log
just need to put the amps in and wire it up, hopefully the bus bars get here before sat or im going to have to figure out a way to get it all hooked up for the comp sat.
sometime next week i will be attemping to make some beauty pannels for everything
Build Log
bass pulled the mirror apart again, this was glued together with ca glue
Build Log
on my way to school this morning i ended up blowing the level 5. went to rays after and found it like this
heres the other side
i was amazed at how the coil looked, i expected it to be black from the abuse i gave it lol
triple joint ripped and scraped the coil and messed it up
got it ready
Build Log
  • 1 month later...
Well after I blew my lvl 5 I decided I wanted to try something new so I decided to go with a sp4 18.
Had it in this box for a while and we got a 51 out of it. (it wasn't inverted)
Basically started over and removed all the 1/0 and replaced it with 6 runs of 2/0
Put the triple bracket on just can't use it yet. I will be ordering the 3rd alt soon
Then I was talked into going with 2 again so I put this box back in lol.
Build Log
Got it finished just in time for Meca. Keep in mind this is with like 5 min of testing and 1 new sub, the other one is partially broken in.
This is at the headrest
Popping fuses. First it was the 2 minis then the anl fuses. Not all at once
I know it's got more in it. We will see once i get to test some more
Build Log
  • Who's Online   0 Members, 0 Anonymous, 2687 Guests (See full list)
