ok so heres the deal, i came up with what i thought were good dimensions, built the box, and tada tuned waaaaaaayyyy too high i guess. finally got to get torres and punched in the specs per side ( divided box, both sides ported) and when i punched in the specs 60hz is what i got. i want mid 30s. this one has 16in tall by 6in wide port.
this one i come up with after using torres 16in tall by 3 in wide give me 36hz
what im trying to figure out is if there was any way to modify the box i just built to be tuned right
03 tahoe z71
4 death penalty 18s
2 ampere audio 3800s @ .5 each
18v
156.7 @ 35hz
158.5 @ 50hz
How wide is the opening inside the box? Looks like it is ~6". Are you adding the length created by that corner into the port length calculations?
Current system:
Previous systems:
the way ive been told to figure port length is:
start of port to back wall+side wall to end of port-width of port
and the port is currently 6in all the through
03 tahoe z71
4 death penalty 18s
18v
156.7 @ 35hz
158.5 @ 50hz
What are the external dimensions of that box?
Current system:
Previous systems:
im wanting the tuning to be best for musical. down and dirty wicked bass
03 tahoe z71
4 death penalty 18s
18v
156.7 @ 35hz
158.5 @ 50hz
ok tell me if these seem right. the picture of the box is 6in longer than my original and different port design.
03 tahoe z71
4 death penalty 18s
18v
156.7 @ 35hz
158.5 @ 50hz
Posted (edited)
Thought the port area are had to be within the port area range? Then again idk how the calculator box works :unsure:
Edited by 97Jetta1637
#teamihop
Two 12 inch DC XL's
Carbon Fiber Cap
Stetsom 7k
Shell of box / baffle built by me
Port / sealing the box by John Hone
Fuck midrange
Alpine-9886
http://www.stevemeadedesigns.com/board/topic/177428-97jettas-sql-trunk-wall-loudest-99-buick-century-custom-with-a-one-legged-owner/
price has no influence on how something sounds
I told him to move the fucking port.
they see me hoppin they stoppin they can't believe im so white and dirty
It looks like you got so drunk, that someone came up and stole your leg.
i think it is supposed to. i didnt realize that but i did some changes and its now in between the port area range. i had to add an inch to the width and 10" to the length and it gave me 34hz.
03 tahoe z71
4 death penalty 18s
18v
156.7 @ 35hz
158.5 @ 50hz
