jbiddle.com Posted February 13, 2012 Report Posted February 13, 2012 Hi there guys, i will assure you that this is not my first system and not my loudest either. but i am looking for something a little new i already know what kind of box i am building. its going in a single cab truck so its a center sonsol as well. so internal net volume of box is about 4 cubic feet, i will then fill it with 5 lbs of poly. fill. this will make the two woofers act like there in a 5 cube enclosure. i know all of the bassics and everything about building boxes i am just torn about the kind of sub and amp i want to run. i have a pretty nice budget of about 350 dollars per sub. i am really considering the JBL Gti MkII 12's but does any one have any better recomendations for that price range?? also the sub box is going to be tuned to between 31 and 33hz using four 4" aero ports. in this set up the subs will be mounted in the center consol between the seats and the four 4" aero ports will be behind the seats two on each side i will post pix of my build progress with this box as i go along and hopefully you guys can tell me what you like and dis like about it all. and as for the subs the biggest i can go is two 12" subs. Head Unit -- Alpine CDA-9887 Mids and highs -- 2 Crescendo PWX-8's 4 Crescendo PWX-6's 4 Crescendo FT-1 Super tweeters Mids and Highs amps -- 2 Alpine V12 MRV-F545 Subs -- TBD Sub amp -- Crescendo Bass Cleff BC2000. Sub Box -- Ported box 9 cubic foot tuned to 37hz for 2 15 with 140 inch port area Processor - Alpine imprint
jbiddle.com Posted February 13, 2012 Author Report Posted February 13, 2012 between 1400 and 1600 RMS torn between amps as well may want to get an alpine MPR 2000 i really am not deead set on anything yet i just know i can have two 12's Head Unit -- Alpine CDA-9887 Mids and highs -- 2 Crescendo PWX-8's 4 Crescendo PWX-6's 4 Crescendo FT-1 Super tweeters Mids and Highs amps -- 2 Alpine V12 MRV-F545 Subs -- TBD Sub amp -- Crescendo Bass Cleff BC2000. Sub Box -- Ported box 9 cubic foot tuned to 37hz for 2 15 with 140 inch port area Processor - Alpine imprint
jbiddle.com Posted February 13, 2012 Author Report Posted February 13, 2012 $350 Per sub $500 for amp and i already have a nice head unit Head Unit -- Alpine CDA-9887 Mids and highs -- 2 Crescendo PWX-8's 4 Crescendo PWX-6's 4 Crescendo FT-1 Super tweeters Mids and Highs amps -- 2 Alpine V12 MRV-F545 Subs -- TBD Sub amp -- Crescendo Bass Cleff BC2000. Sub Box -- Ported box 9 cubic foot tuned to 37hz for 2 15 with 140 inch port area Processor - Alpine imprint
ehckz Posted February 13, 2012 Report Posted February 13, 2012 Most 12s from brands on this site would probably sufficient. As for an amp if you wanted a little more power you could get an AQ 2200d for like 440 shipped...not a bad deal. Build In Progress for Slamology 2013 3 m1xl 18s walled in a gti 1 5k 4 batts audio technix 1/0 8 cheap r/f 6.5s mb quart 4.60
jbiddle.com Posted February 13, 2012 Author Report Posted February 13, 2012 yeah the aq stuff is really nice Head Unit -- Alpine CDA-9887 Mids and highs -- 2 Crescendo PWX-8's 4 Crescendo PWX-6's 4 Crescendo FT-1 Super tweeters Mids and Highs amps -- 2 Alpine V12 MRV-F545 Subs -- TBD Sub amp -- Crescendo Bass Cleff BC2000. Sub Box -- Ported box 9 cubic foot tuned to 37hz for 2 15 with 140 inch port area Processor - Alpine imprint
