Well its not the taurus in my sig. I currently have a 2008 Chrysler 300 and Im trying to keep everything close to stock with the exception of the audio. But Id like to not tear anything up with mods. Im just trying to make a clean sounding SQ/SPL build that get loud but isn't rattle as all get out.
Now I did make a slot ported box for the 2 DC 8 m2s and it sounds good but not great. I recently built a tline for my sister's 08 Jeep Compass and was quite impressed with the results of the SA-8 t-line with 400 rms.
Edited by SojiaRaggs9000
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
Ok I sketched up a couple of "tries". Basicly I'm just trying to figure out the port. (I know the height is incorrect Im not worried about that at the moment.) The lengths arn't 100% dead on either but I'll fix it after I know which to go with.. Or if Im even in the same ball park on finding the taper.
This on is just a classic t-line. No taper just the same port (5.25")
This one is the style Ronnie suggested. I adjusted inside wall of the port up 3.25" and lowerd the other end 3.25" (give or take) Why 3.25", I don't know I guess because it half of 5.25"?
This one Soapbox suggested. I started with 5.25" to 1.75" to 2.75" and ended with 5.25". Why these numbers , I don't know maybe because 5.25" / 3 is 1.75. And 1.75" + 2.75" = 5.25"
no one?
Have you considered that the box doesn't need to be a rectangle? But more of the shape of your trunk? I have attached a T-Line design that I have NOT constructed yet, but it seem to be a sound design. It was designed( of course with minor restrictions) to fit in a space that is 24"L x 26"W (for 15 3/4", then 46"W for 8 1/4") x 12.5"H. With the length of the port being about 87-88" or yielding about 38Hz tune with the Fs =37Hz of the DD-508b's I am going to use.DSCN2980.jpg
  • Who's Online   0 Members, 0 Anonymous, 1225 Guests (See full list)
