help using my smd dd1
Some have a really weak output on the RCAs and the dd-1 doesn't get enough input voltage to work properly. Not sure if this would be the case with your head unit, but it's something to think about
Edited by SnowDrifter
i tested each SET of rcas to find there max. my rca for mids and highs was 36 volume and sub rcas was 38. so therfore max volume is 36 do for each set of rcas and each amp
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
and this is to set the deck only correct ?
Yes
Yes
so after i set my deck do i just plug the rca's back into the amps and use the + and - wire set to set my gain's on both my amps at the volume my deck go up to with all settings on my deck turn to flat and even on my amps
Yes
No. DD-1 clip to ground, put the probe on the + on the amp.
Did you even open the manual? It tells you how to do ALL of this
  • Who's Online   1 Member, 0 Anonymous, 1544 Guests (See full list)
