Erwindmac Suz Posted February 26, 2012 Author Report Share Posted February 26, 2012 Did you read the manual? It tells you to turn the crossover all the way up yes i did it said turn it all to flat which i figure was turn off Quote Link to comment Share on other sites More sharing options...
MIKE-2U Posted February 26, 2012 Report Share Posted February 26, 2012 doesnt matter. i used red. Quote 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd Link to comment Share on other sites More sharing options...
Erwindmac Suz Posted February 26, 2012 Author Report Share Posted February 26, 2012 doesnt matter. i used red. now what about my 2 amps do i just leave the rca's hook up to the amps and use the speaker + and - after i set my deck Quote Link to comment Share on other sites More sharing options...
SnowDrifter Posted February 26, 2012 Report Share Posted February 26, 2012 (edited) Some have a really weak output on the RCAs and the dd-1 doesn't get enough input voltage to work properly. Not sure if this would be the case with your head unit, but it's something to think about Edited February 26, 2012 by SnowDrifter Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
MIKE-2U Posted February 26, 2012 Report Share Posted February 26, 2012 i tested each SET of rcas to find there max. my rca for mids and highs was 36 volume and sub rcas was 38. so therfore max volume is 36 do for each set of rcas and each amp Quote 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd Link to comment Share on other sites More sharing options...
Erwindmac Suz Posted February 26, 2012 Author Report Share Posted February 26, 2012 Some have a really weak output on the RCAs and the dd-1 doesn't get enough input voltage to work properly i have a eclipse cd5030 Quote Link to comment Share on other sites More sharing options...
Erwindmac Suz Posted February 26, 2012 Author Report Share Posted February 26, 2012 i tested each SET of rcas to find there max. my rca for mids and highs was 36 volume and sub rcas was 38. so therfore max volume is 36 do for each set of rcas and each amp and this is to set the deck only correct ? Quote Link to comment Share on other sites More sharing options...
SnowDrifter Posted February 26, 2012 Report Share Posted February 26, 2012 i tested each SET of rcas to find there max. my rca for mids and highs was 36 volume and sub rcas was 38. so therfore max volume is 36 do for each set of rcas and each amp and this is to set the deck only correct ? Yes Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
Erwindmac Suz Posted February 26, 2012 Author Report Share Posted February 26, 2012 i tested each SET of rcas to find there max. my rca for mids and highs was 36 volume and sub rcas was 38. so therfore max volume is 36 do for each set of rcas and each amp and this is to set the deck only correct ? Yes so after i set my deck do i just plug the rca's back into the amps and use the + and - wire set to set my gain's on both my amps at the volume my deck go up to with all settings on my deck turn to flat and even on my amps Quote Link to comment Share on other sites More sharing options...
SnowDrifter Posted February 26, 2012 Report Share Posted February 26, 2012 i tested each SET of rcas to find there max. my rca for mids and highs was 36 volume and sub rcas was 38. so therfore max volume is 36 do for each set of rcas and each amp and this is to set the deck only correct ? Yes so after i set my deck do i just plug the rca's back into the amps and use the + and - wire set to set my gain's on both my amps at the volume my deck go up to with all settings on my deck turn to flat and even on my amps No. DD-1 clip to ground, put the probe on the + on the amp. Did you even open the manual? It tells you how to do ALL of this Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
