memphismanx88 Posted October 31, 2006 Report Posted October 31, 2006 hey my friend has a memphis m3 mojo in a 3 cube foot sealed box and we had a earthquake phd5000 watt amp on it with it turned down then he hooked up his new directed class d 2400 watt amp to it and could barley turn the amp up. is it because the amp is crap or because the box is to small thanx
Cuseikan Posted November 3, 2006 Report Posted November 3, 2006 3cubes sealed is pretty big. It may be the gains on the amp that's causing the poping. Was it a 12" or 15"?
AP Zoutes Posted November 3, 2006 Report Posted November 3, 2006 the box is big what sixe sub and which amp is popping...I've seen alot of complaints with the 2400d boards
memphismanx88 Posted November 3, 2006 Author Report Posted November 3, 2006 he has the 15 and the directed d 2400 mono you can go to http://www.directed.com/audio/amps/default.asp to see the amplifier thanx
AP Zoutes Posted November 3, 2006 Report Posted November 3, 2006 Box size seems to be perfect for that sub....probably the amp
SPLGEO Posted November 3, 2006 Report Posted November 3, 2006 box is right for teh sub.. COUGH go ported Cough...... its 100% amp,, or amp area,, 1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
