MrFree Posted February 27, 2012 Report Posted February 27, 2012 Hello everyone I just wired my dual voice coil Orion XTR124(x2). I wired them at 2 ohms and put one speaker on the left +,- terminal and the same for the right..So I should have 2ohm stereo!?!?..Does anybody know why the speakers arent working now..I have it + to + and - to - per speaker on stereo,so its not bridged..Also I have a Coustic600 se..any ideas please... R.I.P...99'Dodge Grand Caravan 03 Lancer Oz Big 3 HU-JVC KD-530 RCA's-rockerfosgate 41/2 inch Infinity mids Subs-(12's)2 Orion xtr124 Amp-Coustic600se battery-2 x stock, 1x Shuriken SK-BT20 Box-L-ported 3.562cubes@35Hz miscellaneous-stinger volt-meter, gain nob, (coming soon bass pro,eq,line drive) I dont have flex yet but damn I sound good,(coming soon....flex) Check out my HHR install Everything I install or build here:http://s1160.photobu...s/q485/MrBfree/ Also video's of my Car with the new box.http://www.youtube.c...lentGyge/videos
Guest Posted February 27, 2012 Report Posted February 27, 2012 rca's are good? sub preout on headunit turned on? did the amp work before? is the amp even on?
LoudBimmer Posted February 27, 2012 Report Posted February 27, 2012 Most likely RCA output is bad. Had this problem before, ended up replacing HU.
MrFree Posted February 28, 2012 Author Report Posted February 28, 2012 yes the amp is on! I had the radio on pause and I adjusted the wires. It will work with one speaker wired at 2ohms mono but not on stereo And since I had a problem with 2ohm stereo I just wired both speakers to 1ohm mono and it works but when I try to run 2ohm stereo I get nothing.When the specs say 2x300@2ohm stereo..Recap...YES my amp is on I am currently bumping at 1ohm.I have 2 12" Orion xtr124's they are both wired separate at 2ohms(both terminals on each speaker is wired together at 2ohms)..My amp specs say 1x600@4ohms mono,2 x 150@4ohms stereo, AND 2 x 300@2ohms stereo.But for some reason the amp doesnt work at 2ohm stereo..but will work at 1ohm mono when its not rated for it I dont think R.I.P...99'Dodge Grand Caravan 03 Lancer Oz Big 3 HU-JVC KD-530 RCA's-rockerfosgate 41/2 inch Infinity mids Subs-(12's)2 Orion xtr124 Amp-Coustic600se battery-2 x stock, 1x Shuriken SK-BT20 Box-L-ported 3.562cubes@35Hz miscellaneous-stinger volt-meter, gain nob, (coming soon bass pro,eq,line drive) I dont have flex yet but damn I sound good,(coming soon....flex) Check out my HHR install Everything I install or build here:http://s1160.photobu...s/q485/MrBfree/ Also video's of my Car with the new box.http://www.youtube.c...lentGyge/videos
