kfx400kid Posted February 27, 2012 Report Posted February 27, 2012 I need some help with the port for my box that i am trying to build, i have used the torres box calculator and have come up with a box that is 20h x 38w x 24d. The subs will be facing up and the port is going on the back of the box facing the hatch in the middle. For a port i have 18.5h x 28d and i have .5ft3 for woofer displacment and have it check for using three common walls. Now the port opening is 5" so were is make the L i have to make it 2.5" from the back on each side. No from this point on i am lost as to what to cut the boards to. I know that it won't be 28" long but i am not sure what the length with be and any help would be great..... $t3v!3 G.......
stevenE140 Posted March 2, 2012 Report Posted March 2, 2012 use re audios box calculator and type in all your dimentions it tells you what to cut your wood to 2 American bass xfl 15 aq 2200d 2 sq8d midrange 6 vfl65mr midrange vfl 350.4 four channel (2)kinnetic 2400
