ZeroxD Posted February 28, 2012 Report Posted February 28, 2012 If I'm gonna be running two alpine type r's will I need a bigger alt? Or can a 1997-2003 f-150 handle this? (daily driver)
slaughter Posted February 28, 2012 Report Posted February 28, 2012 no you dont need an alt but it could never hurt. SOLD 2006 Ford Ranger Single Cab2 DC XL 15's2 Crescendo BC2k's4th Order Blowthrough CURRENT 2012 Dodge Charger R/T 2 Tantric HD 12's Ampere 3800 2 XS XP 3000's
pa-pa-platypus Posted February 28, 2012 Report Posted February 28, 2012 subs dont dictate the electrical needed the amp being used does This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
ZeroxD Posted February 28, 2012 Author Report Posted February 28, 2012 Well anyone know of an amp that can 600 watts @ 4 ohms for two subs?
pa-pa-platypus Posted February 28, 2012 Report Posted February 28, 2012 what voice coils are they? im guessing dual 4? This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
pa-pa-platypus Posted February 28, 2012 Report Posted February 28, 2012 well then youre looking for an that can put out 1200ish at 1 ohm see diagram ---> http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42#results...uhm its basically gonna depend on budget theres loads of good amps than put out that power at 1ohm This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
