Crazycaraudio Posted March 2, 2012 Report Posted March 2, 2012 i was wondering what do i need to have a on/off switch for my amp. people have told me to run it from the ignition or hu. would i just splice the remote wire from the hu running to the amp. which would be easiest? oh yeah i have a xscorpion voltmeter that doesnt have a remote wire and it wont turn off i want to hook it up to the battery to watch voltage. i would splice the power wire from the igition to it. or get a remote wire for it? sorry for the noob questions but im just getting into the basshead seen.
Loslam Posted March 2, 2012 Report Posted March 2, 2012 For the amp question, yes have a toggle switch for the remote wire, easiest. For the meter that won't turn off, have a toggle switch for it as well. Unless you have to calibrate it every time it reads power. Good luck Edit: Yes from headunit->to switch->to amp. 1997 Chevrolet Silverado Extended Cab, 350 Vortec Things to come at some point... Build Log: http://www.stevemead...2200ds-133-ohm/
Crazycaraudio Posted March 2, 2012 Author Report Posted March 2, 2012 what size power,ground and remote wire do i need to run the toggle switch. and is there a a wire that is actually like a remote wire or and i just use a power wire for the switch.
c.director Posted March 2, 2012 Report Posted March 2, 2012 its power wire, like 20 awg would be plenty im sure. take your remote from your head unit to a switch and then from the switch to a relay (so you can power all you want), and then to your amps, voltmeter, etc. Facebook: http://www.facebook.com/caleb.arnold.9809 YouTube: http://www.youtube.com/user/CustomAudioChannel?feature=watch
NT_Hardcore Posted March 2, 2012 Report Posted March 2, 2012 if u have a remote wire why are you needing a switch?
Crazycaraudio Posted March 3, 2012 Author Report Posted March 3, 2012 dont have a remote wire. i just got to splice power wire to remote wire on amp them just ground the other wire right? could i use old speaker wire from my old 5.25 speakers for wire for the toggle switch?
c.director Posted March 3, 2012 Report Posted March 3, 2012 ^^ yes that will work, (just wire the switch inline with the positive) and you can fuse tap if you want a "remote wire" that will turn off with the car. go for the 12 volt acc outlet or similar. Facebook: http://www.facebook.com/caleb.arnold.9809 YouTube: http://www.youtube.com/user/CustomAudioChannel?feature=watch
