so I know most of you are familiar with my 69 chevelle build, but i figured i should show my daily driver some love and make a thread for the build i did for it a while back. its a 2005 dodge ram 1500 quad cab. so without rambling on too much, lets just get to the pictures.
first, the equipment
alpine 9835
dd m1a and dd s4
ID ctx65cs comps up front and ID oem 6.5s for rear fill
dc level 4 10" dual 2
120sq ft of damplifier
stnger spv70 battery and some of the wiring
Edited by zx10intn
1969 Chevy Chevelle
20/22" staggered Bonspeed Huntingtons wrapped in Nitto INVO's
Mechman 250amp cs144 alt w/AVBM
Kinetik 1800 main battery/Kinetik 2400 in the trunk
Pioneer AVH-3200dvd Headunit
(2) sets of Hybrid Audio Technologies Imagine components up front
(2) DD 3512's d4 coils
Sundown sax100.4 component amp
Sundown saz-3000d subwoofer amp
5ft^3 box tuned to 34hz
MY BUILD
first step was to trim the stock battery tray and fit the oversized stinger battery under there
w/stinger battery
1969 Chevy Chevelle
MY BUILD
time to upgrade the big 3
alt to batt+ udner airbox
picked a spot and cleaned it up for the grounding of the batt and block to frame
grounded and paint sprayed over
all done with the big 3 and zip-tied up
1969 Chevy Chevelle
MY BUILD
time to strip the cab and prepare for the damplifier
1969 Chevy Chevelle
MY BUILD
and time to get going on the damplifier... sealing up the doors, cab, etc
rear doors
front doors
cab interior and floor
1969 Chevy Chevelle
MY BUILD
running the wires through the molex connector and mounting the crossovers behind the front kick panels
through molex
crossovers mounted
kick panel snaps back in with a little persuasion
1969 Chevy Chevelle
MY BUILD
6.5s mounted in rear door and running rca's to the rear from the deck
speakers rings made and mounted
rca's ran and taped down
1969 Chevy Chevelle
MY BUILD
made a bracket to hold the front fuse holder for the main 1/0 run, and of course all the wires are techflexed and heat shrunk
1969 Chevy Chevelle
MY BUILD
next it was time to fab up some tweeter pods, and since at the time i wasnt too swift with fiberglass, i took the opportunity to try a new method and loved it, still use it to this day on new installs because its so cheap, easy and fast. ill step by step this part just in case anyone wants to know how this was done...
take your tweeter trim ring, go to the hardware store and get some PVC end caps that are slightly larger than the diameter of the ring
next, determine what angle you want your pod at and drill a hole at appx that angle into the pvc cap
you will also need some steel nipples, usually sold in the lighting area where lamp cords, plugs etc are sold. they are threaded on the outside and hollow in the middle to allow a lamp cord to pass through. thread it into the hole you drilled into the pvc cap and secure the inside with the nuts provided with the steel nipple lkg
find the spot on your a pillar you want to mount it to and drill a hole for the steel nipple to pass through. push it through the hole and secure it on the backside of the a-pillar with one of the nuts provided in the kit,
now that its in and you have it where you want it, take it back off LOL and find some paint to match your a-pillar and give them a few coats
after drying, place the tweeter into the cap, re-isntall onto the pillar with the tweeter wires passing through the steel nipple and re-install into the vehicle. if your tweeter is slightly too small for your cap wrap a layer or two of electical tape around its sides, just enough to make it a snug fit when you push it into the pod
Edited by zx10intn
1969 Chevy Chevelle
MY BUILD
on to the amp rack to go behind the seats...
cutouts for vents
laying down some color matched carpet
installed on rear wall with both amps
1969 Chevy Chevelle
MY BUILD
