i'm wanting info on how you built your false floor for under the wall and how you secured it to the vehicle?? .
I'm just wanting some ideas for future build and am stumped (been away from audioz to long :( )
photos are worth 10000 words ha
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
i dont own a walled off car yet but i would imagine you build a frame for support(2x4's etc) bolt them to the floor in the car(chassis if you can swing it) and go from there. it also gives you something to secure the bottom sheet of MDF to so you dont run into any problems with gas tank and hitting things your not supposed to.
Built the box in the van. Used the 3rd row seat hold downs to bolt the box in place. Could have done more, but it isn't moving unless there is a catastrophe.
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
see i've built one before long long ago and just kinda slapped it together thought it was good enough and never really did much with it so now i'm looking to do proper way of doing it
i was thinking of welding in some 5/8" bolts to the floor pan back there and using threaded rod to hold wall down and then secure to back where cut out is with some all thread.. (i donno where im going with this)
i dont wanna make it permanent and want to be able to remove it later on down the road
this is what i have to work with
R.I.P!
(Nov-29-2009)
92 explorer
current build
Well, here is 20000 words, haha
Not much to mine really, but if you've seen my build log, then you know i had to beat my wall in the last 4 to 5 inches of the way. That things not going anywhere.
Edited by 2loudisjustright
2000 zx2: Rebuild with 8 12s on a 10k underway!!
MY BUILD LOG
now i like the look of that its simple looking on the outside haha
but whats the inside look like- just bunch 2x4s stacked or what
R.I.P!
(Nov-29-2009)
92 explorer
current build
go under the car and bolt that sucker down. dont weld it
I made a 2x4 frame then drilled and bolted it through the floor n tightened it with a impact wrench. Then jus glued/screwed the mdf bottom sheet to the frame
2000 stratus10 SunDown E-10s
Singer 250amp Alt
Xs Power D975Concept c2400All 0 gauge wire10 6 1/2's in Rear Doors
Nope. The two pieces of board you see is it. But when i put the double layered box in and screwed it to the platform, its like being 3 layers thick on the bottom. Three 3/4 layers wont hardly give any!!
MY BUILD LOG
well this is what i came up with
some coupling bolts welded up to some angle iron with hole drilled into it
attached to seat belt bolt
drilled some holes in some flat bar and bent it up to fit the seat mount
2x4 screwed to it
glued down the mdf with 3/16" area routed out so the box is flush
and its bolted in for now while glue dries (the alt hread will be unscrewed and box will be put in and bolted down to vehicle as well)
R.I.P!
(Nov-29-2009)
92 explorer
current build
