Yes, not doing the big 3 is most likely the problem. And i should prolly do it for future projects.
Thanks alot
"I don't fuck with bitch niggas, partner"
Thanks alot
No problem. Also, you should probably listen to Loslam and check your amp ground as well.
97 Suburban
8 custom PSI Platform 3 18's
Thanks alot
My ground is to the chassis and the paint is sanded, all is good there.
Thanks alot
Sounds good. Now on to that big 3!
97 Suburban
