04SDExplorer Posted March 14, 2012 Report Posted March 14, 2012 ONE of my nightshades has a rattle to it, but full tilt it sounds normal and pounds like normal. I was thinking the dust cap came loose but it didn't. If I grab the cone I can shift it side to side. ANyone know what might be the problem? I haven't taken it out yet to examine it but I'm hoping it's able to be fixed without having to re cone it. Quote 2004 Explorer Limited 24" Lexani "pyros" wrapped in 255/30/24 pirelli's 270 Amp MechMan Alt. (2)Stinger SPP-2150's (2)Sundown NightShade 15's IA 40.1
andrew018018 Posted March 14, 2012 Report Posted March 14, 2012 it sounds like spider issues.. did you check to see if the spider is starting to break away from the basket? Quote My System (in VW golf/Rabbit mk2) (1) Hifonics Brutus 2010D @ 1ohm (1) Hifonics Zeus 440 Mids'nhighs (3) JBL W10Gti subs (2) JBL GTO838 (2) JBL GTO936 (1) run of 3/0 Gauge ofc (1) Ac Delco120ah 850cca battery (front) (1) Ac Delco 45ah 330cca battery (rear) (1)Sony Gt630ui hu 34hz tuning
04SDExplorer Posted March 14, 2012 Author Report Posted March 14, 2012 No not yet, I'm pulling the sub out tomorrow..also at low volumes if I press down the middle of the cone the rattle stops. Are most issues like this with the spiders fixable? Quote 2004 Explorer Limited 24" Lexani "pyros" wrapped in 255/30/24 pirelli's 270 Amp MechMan Alt. (2)Stinger SPP-2150's (2)Sundown NightShade 15's IA 40.1
andrew018018 Posted March 14, 2012 Report Posted March 14, 2012 if its glue failure it could be fixable, but i guess when you pull it out you will find out Quote My System (in VW golf/Rabbit mk2) (1) Hifonics Brutus 2010D @ 1ohm (1) Hifonics Zeus 440 Mids'nhighs (3) JBL W10Gti subs (2) JBL GTO838 (2) JBL GTO936 (1) run of 3/0 Gauge ofc (1) Ac Delco120ah 850cca battery (front) (1) Ac Delco 45ah 330cca battery (rear) (1)Sony Gt630ui hu 34hz tuning
