Yes I would do a box specifically to compete..or I guess you will lose..lol.. after all is a couple 12"s box, no big deal to exchange.
Ok so here are the port dimensions:
Enclosure Specifications:
Fb = 35.094 Hz
Vb = 3.285 ft^3
Subwoofer Mounting = Front Mounted
External Height = 12 in
External Width = 40.75 in
External Depth = 20 in
Port Width = 4 3/4 in
Cut Sheet List:
* All Dimensions in Inches.
Shared Port Internal Assembly Parts:
2 x Front to Back = 16 1/8 x 10 1/2
2 x Extension = 3 13/16 x 10 1/2
A second baffle layer on the top should be added if possible, if you already have it le me know as some calculations may change.
If you can do angled cuts, I will give you infos on the 45s and the center deflector that can improve performance of the box, a side port option is available in case you prefer it.
thank you, i have not added a second baffle yet. i think i can do 45's. on the extensions are they at the end of the port wall (where it would be narrower to back wall) or to side of the port wall? what program does all of this?
Let me show you all you can do inside this type of design:
The center deflector is most important optimization as it avoids the lateral airstreams colliding head on (it has to be done correctly as shown), but this shows other optimizations and bracing that can be done, You can figure out the length of the port parts with any calculator and/or sketchup (measuring along the centerline of the ducts ).
If your dimensions don't include the double baffle that's best, I placed the second layer on top of your original dimensions so the design above does not change, just place the second layer on the top if you want to do the bouble baffle, it's highly recommended.
Ok Terry Zona, about the center deflector you need to make sure that the width never goes lower than 2 3/8" so making that piece larger than it needs to be will detune the port, if I can help with anything let me know.
  • Who's Online   0 Members, 0 Anonymous, 861 Guests (See full list)
