lgn0213 Posted December 14, 2007 Report Share Posted December 14, 2007 How would I Bridge this amp or can I? Because I tried moving the wires around and it doesn't sound any different? Its a Hifonics Titian TXi7506 Link to comment Share on other sites More sharing options...
dmanson Posted December 14, 2007 Report Share Posted December 14, 2007 first off do you have the manual for that amp and if not then you can always go to www.maxsonics.com and get it. now i'd mostly like say twist both + speaker wires together and then twist both - speaker wires together ........ insert the + into the first + on the amp and then with the - speaker wire insert it into the first - on the amp. both + and - are internally bridged on that amp so it'll see whatever ohm whichever way you wire it. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module Link to comment Share on other sites More sharing options...
