I don't know if a WALL is a good idea for a first system. Maybe you should start with an under window line design first and see what all that entails. Also, is your truck capable of being set up for twin alternators? If not, you're very limited on the type of system you can get in there. Takes a lot of power to do what you're wanting.
Shit, with a welder you can do as many alt's as your want. Only problem is space and power of the motor ;)
Room for alternators and said bracket are the issue with the Ridgeline. I'll be stoked as hell to see how this thing come together. If you don't have the space to make power however, you're gonna have a hard time spending power for any length of time.
Assuming an amp efficiency of 75% and a voltage of an even 14 volts, those amps will pull over 650 amps at full tilt. That's a LOTTTT of draw.
