Want to upgrade battery?
Hi all so i have a 06 Cadillac cts with a acdelco battery cca 690 AH63.
My audio system so far is a 4ch Mb-quart onx 4.60 i want to up grade my battery because sometimes i play my system while cleaning my car and dont want to worry about killing the battery.(i happened to me once)
I know i should not crank up the system with the car off,but you get what i'm saying.
So what is a good battery to put under my hood so this will not happen again?
P.s. i will also add a 1500 watt amp and sub in the near future.
Thank you in advanced and please be easy on me :help:
2009 bmw 5 series
Head Unit Stock
Amplifier-JL Audio JX 360/4
Processor- Audiocontrol LC6
an amp that small will not put any more than a 12.5 amp load and thats if your running two ohms a channel, thats about how much power your blower motor will pull. Now when you upgrade to the 1500 watt amp then you will need to do the big three and 2 small batts(20 or 30 ah) or one decent batt(50 or 60ah), How long did you play it for with the car off, If it was like 10-20 mins and your battery died then u might just need to get ur batt and charging system tested
i'm running a 4ohm load a channel. im in the process of doing the big3 upgrade but with this caddy getting to the positive terminal on the alt is a PITA.
my battery now has 63ah.
2009 bmw 5 series
Head Unit Stock
thanks,damn caddys smh. but i love it.
2009 bmw 5 series
Head Unit Stock
  • Who's Online   0 Members, 0 Anonymous, 1934 Guests (See full list)
