Banshee421 Posted March 26, 2012 Report Posted March 26, 2012 Ok 1 amp is in all ready 600 watts on 4 gauge 2 channal. I have other amp that needs 1/0 wire do I just run onther from battery back again. Or should I do 1/0 solo to a disturbution block and split from there.
IBleedMusick Posted March 26, 2012 Report Posted March 26, 2012 Ok 1 amp is in all ready 600 watts on 4 gauge 2 channal. I have other amp that needs 1/0 wire do I just run onther from battery back again. Or should I do 1/0 solo to a disturbution block and split from there. I would do 1 fresh run of 1/0 to the back with a distroblock that splits into two 1/0 or 4 gauge connections. They make some that have adapters for 1/0 or 4 gauge or some that have different sizes. 2013 Dodge Charger Build Log 1996 Ford Explorer XLT 5.0Build Log 2005 Honda Civic LX Coupe Build Log SMD SUPER SELLER!!!!My Selling Feedback
Banshee421 Posted March 26, 2012 Author Report Posted March 26, 2012 That what I had in mind but now the big amp has to share the 1/0.
Guest Posted March 26, 2012 Report Posted March 26, 2012 well how big is the sub amp? you wont run into problems if its like 2000w or so, as 0 gauge can handle upwards of 300 amps so that leaves buffer room for the 600w amp
Banshee421 Posted March 26, 2012 Author Report Posted March 26, 2012 Ok yea its a Skar 1500 and a cheap alfphasonik for highs 150x2 4 ohm and full 1500 @ 1 ohm on Skar for 2 sa 12s.
Banshee421 Posted March 27, 2012 Author Report Posted March 27, 2012 2 different grounds or disturbution 2 into 1 ground.
c.director Posted March 28, 2012 Report Posted March 28, 2012 2 different grounds or disturbution 2 into 1 ground. Ive heard people recommend separately, but I've eliminated engine noise in several systems by moving all the grounds to one spot through a d-block Facebook: http://www.facebook.com/caleb.arnold.9809 YouTube: http://www.youtube.com/user/CustomAudioChannel?feature=watch
