It explodes?
lol, the stuff is so soft, unless you have a counter sink bit it can get ugly. I used to just jigsaw my boards and then slam screws in it and silicone the hell out of everything and not even paint. Ever notiice how the baffle will lift off the board behind it unless you have it glued already or pre-drill? good times, good times...
if you have normal drill bit you can do it to simple take some tape wrap it around bit where you want to stop the the bit from going any farther into wood and just drill up to there takes some time but you can get good results by doing this
R.I.P!
(Nov-29-2009)
92 explorer
current build
i dont know if its cheaper or not but i use red devil lightweight spackling compound on the outside edges and screw holes, it sands easy, and never pops loose, and i always have a ton of it being as im a union painter.
these orphans aren't going to feast on themselves
