help
GregoryGoodII
1600w for $450....
edit: LOL Max power output (15.2V, 15%THD): 10,000 watts x 1 chan.
same as kranny, not to much to tell unless you use it yourself.
#teamihop
Two 12 inch DC XL's
Carbon Fiber Cap
Stetsom 7k
Shell of box / baffle built by me
Port / sealing the box by John Hone
Fuck midrange
Alpine-9886
http://www.stevemeadedesigns.com/board/topic/177428-97jettas-sql-trunk-wall-loudest-99-buick-century-custom-with-a-one-legged-owner/
price has no influence on how something sounds
I told him to move the fucking port.
they see me hoppin they stoppin they can't believe im so white and dirty
It looks like you got so drunk, that someone came up and stole your leg.
i am gonna start by saying one set of 0 gauge terminals for 5000w not a chance and MOST of the time when an amp takes a maxi fuse its a piece of crap. i would say u might get 1400 to 1700 watts if your lucky. for the money i would go audioque 2200
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
DVI-10000
0.0/5 rating (0 votes)
Description
  • Vicious Series Monoblock Class D Car Amplifier
  • RMS Power Rating (14.4V):
  • 4 ohms: 1600 watts x 1 chan.
  • 2 ohms: 2200 watts x 1 chan.
  • 1 Ohm: 5000 watts x 1 chan
  • Max power output (15.2V, 15%THD): 10,000 watts x 1 chan.
  • Pulse Width Modulated MOSFET power supply
  • Wired remote bass level control included
  • LED power (green) and protect (red) indicators
  • Variable Bass Boost (0 to +18 dB bass boost at 45 Hz)
  • Soft Start Turn-on
  • Mono channel operation
  • Speaker-level (high-level) inputs with signal sensing for automatic turn-on
  • Preamp RCA outputs to daisy chain multiple amps
  • System Protection circuitry
  • Illuminated Absolute badge
  • Heavy duty aluminum alloy heatsink for extreme heat dissipation
  • Silver-plated RCA level inputs
  • Silver-plated screw terminals
  • Input sensitivity:
  • Level: 200mV-6V
  • Variable low-pass filter (35-250 Hz, 24 dB/octave)
  • Subsonic filter (10-50 Hz)
  • Phase Shift: 0-180°
  • Damping factor: >120
  • Frequency response: 10-250 Hz
  • Dimensions: 21-13/16"L x 10-1/2"W x 2-1/2"H
  • Minimum 4-gauge power and ground wiring is required for installation.
  • Designed and Engineered in the USA
  • 1-year Manufacturer's warranty
your not even gonna get close to the rated at 1ohm
there is some VERY hard headed people out there. Anyone who says a DD-1 isnt necessary is also saying an O-scope isnt necessary. Anyone who says an O-scope IN THE MINIMUM isnt necessary, is a noob. Forget the DD-1 for a minute, any reputable installer will at LEAST use an O-scope. Those guys in that thread are clowns. Hard headed clowns.
  • Who's Online   0 Members, 0 Anonymous, 1236 Guests (See full list)
