Renault trafic SQL Build from Scotland ...
and while i remember the door grills were modified by us to to help the sq side of things original grills removed replaced with stainless steel welding wire these had to be done to keep in the parameters of the sq competition rule book
and it worked brought this home from the UK Finals
  • 6 months later...
time for a wee updated ..after more listening and more tweaking we found the main problem we then had was reflections from the tweeters causing a slight echo-ing effect which we found out by covering the rear wall behind the seats with nothing more than a sleeping bag
then after we had found the cure we needed to make it more permanent so the dynaliner came out
seats out and rear walls done
