RobertJasonRuiz Posted April 10, 2012 Report Share Posted April 10, 2012 what is this adapter for? on the manuel it says for full range use a y-adapter ,not sure what it's for can you guys give me sum info .... Link to comment Share on other sites More sharing options...
Team Maxxsonics John Posted April 11, 2012 Report Share Posted April 11, 2012 If your head unit has a designated subwoofer RCA output, you will not need a Y-Adaptor. If it does not, you will need to use one of the front or rear RCA outputs. Each front and rear RCA output cables has a left and right...pick any one and use a Y-Adaptor so that you are bringing in a mono signal into the amp and not aleft/right stereo input. The manual explains this but if you are not sure, call maxxsonics tech support department at (847) 540-7700. Link to comment Share on other sites More sharing options...
