Cardboardcat15 Posted April 12, 2012 Report Share Posted April 12, 2012 http://www.youtube.com/watch?v=kdIPHOX5f4c&feature=plcp&context=C4db33b3VDvjVQa1PpcFMlXgBSn-fokXAZAjAr5z8iXV19ZlHPMq0%3D If you're dead set on soldering and only have the closed end ring terminals, just solder them like Audiofanaticz does it. Skip to 1:54 to see how. Honestly, I would suggest crimping. Easier and faster. Just make sure you use a hydraulic crimper. Parts express has some Fuse holders for cheap, I picked up 8 of them recently. Very good deal. http://www.parts-express.com/pe/showdetl.cfm?Partnumber=263-630 As for fuses, just search ebay for ANL fuses. Search your desired amperage and you'll most likely find what you're looking for. Just make sure you buy from a reputable seller. Quote My Channel on YouTube. Check it out for cinematic-style Car Audio videos. https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ New 2014 Scion TC 4th Wall Build https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/ Link to comment Share on other sites More sharing options...
Jessica Posted April 12, 2012 Report Share Posted April 12, 2012 There are tons of retailers out there, sonix, amazon and others. Just double check the hole size in the ring to make sure it matches what you are hooking it to. Quote Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
GSanders17 Posted April 12, 2012 Report Share Posted April 12, 2012 I don't think the ones in the first picture are hard to use, but without a blow torch and solder you may want to stick with a crimp style. They arent that bad, it's just easier to use the second style. The first ones have a lip at the base and it's kind of hard to tell if you got it soldered all the way. And yeah, i use a propane torch and a pair of vice grips since most the time i am by myself when i do this stuff. You mean hand held vice grips? I would burn the hell out of myself if I did that, lol. I'm fortunate to have a table vise to hold the ring terminal for me as I heat it up with the torch. Quote Link to comment Share on other sites More sharing options...
