http://www.youtube.com/watch?v=kdIPHOX5f4c&feature=plcp&context=C4db33b3VDvjVQa1PpcFMlXgBSn-fokXAZAjAr5z8iXV19ZlHPMq0%3D
If you're dead set on soldering and only have the closed end ring terminals, just solder them like Audiofanaticz does it. Skip to 1:54 to see how. Honestly, I would suggest crimping. Easier and faster. Just make sure you use a hydraulic crimper.
Parts express has some Fuse holders for cheap, I picked up 8 of them recently. Very good deal.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=263-630
As for fuses, just search ebay for ANL fuses. Search your desired amperage and you'll most likely find what you're looking for. Just make sure you buy from a reputable seller.
My Channel on YouTube. Check it out for cinematic-style Car Audio videos.
https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ
New 2014 Scion TC 4th Wall Build
https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
I don't think the ones in the first picture are hard to use, but without a blow torch and solder you may want to stick with a crimp style.
They arent that bad, it's just easier to use the second style. The first ones have a lip at the base and it's kind of hard to tell if you got it soldered all the way. And yeah, i use a propane torch and a pair of vice grips since most the time i am by myself when i do this stuff.
You mean hand held vice grips? I would burn the hell out of myself if I did that, lol. I'm fortunate to have a table vise to hold the ring terminal for me as I heat it up with the torch.
  • Who's Online   0 Members, 0 Anonymous, 1973 Guests (See full list)
