1/0 cable runs
are 3 runs of 1/0 positive cable from front batt to back enough for a crescendo 5500d? and how many runs of negative from front to back?...i have a dc 270 xp ,1 xsd6500 under hood and 4 xp3000 in back thnx
you want the same amount of negative runs as the number of positive runs. and if you use OFC it sounds like enough runs. cause lets just say about 100 Amps per 1000 rms. so 550Amps max draw lets say 600 Amps to be safe. each OFC run can supply around 250 amp sto be safe. so you should be good.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Im running a smd350 alt that will charge at 16.8, and also have 4 xs1400 batts in the back.. I need help with my 1/o runs. I was going to run two powers back but im un-sure what to do with the grounds.. The 350 amp alt is going to be a separate system from the stock electrical so do i run two grounds back also? would i ground them to motor block? stock 12 volt batt?
make your own post. and idk a lot sounds wrong in that set up. if you are asking that question and trying to run a 16volt system i would not mess with that.
make anothe rpost and you will get hits
BMW M340 xDrive
  • Who's Online   0 Members, 0 Anonymous, 1405 Guests (See full list)
